vcSinglePositionTargetContainer
A container for a one .
Module: vcRobotics2
Referenced by: vcJointMotionStatement.TargetContainer, vcLinearMotionStatement.TargetContainer, vcPtpMotionStatement.TargetContainer
OwnedTargetvcPositionTargetRGets the target owned by this container, or None.
createTargetvcPositionTargetvcPositionTargetType type,
Optional Keyword[name = String]
Creates a new target into this container.
type (str): Type name of the statement.
Optional: name (str): Name for the new target. If omitted, a name will be automatically generated.
vcPositionTarget: The new target.
ValueError: When the target name is reserved or when the type name is empty or not supported.
NameParametersDescription
OnTargetAddedvcPositionTarget positionInvoked when a new target position is added to the object.
target position (vcPositionTarget): The newly added target position.
OnTargetRemovingvcPositionTarget positionInvoked when a target position is about to be removed from the object.
target position (vcPositionTarget): The target position about to be removed.
